toki »
https://forums.nicoclub.com/toki-u4152.html
Sun Oct 26, 2003 8:42 am
Ok, the way I think I can best some up the sound is if a piece of heatshield were vibrating againt the firewall very steadily...kind of that thin metal hitting thin metal sound, but it is comming from the stereo/AC/shifter area to me, and you can only hear it while in gears 2, 3, and 5 and under throttle...it's pretty quiet, not loud by any means. 4th doesn't really do it all, which is wierd becuase with trannys 2 3 and 4 are usually the ones that go, but it seems to be the worst in 5th actually. I am thinking it's the transmission, but I really don't know. Any ideas? It's like a very steady CSHHHHHH if that helps at all. I know describing a sound isn't going to do much..but you know. Any guesses?
