Quick Throttle body Question
Nismorunner182
Car: 1991 2+2 NA T-Top 300zx
I have an NA and have re wired the vacuum lines because the previous owner had incorrect mapping and the hoses were beginning to show signs of failure.
Upon my investigations, I saw that both of my throttle bodies have two exceptionally large vacuum line hookups. I have seen NA throttle bodies and it doesnt look like that is normal. Do I perhaps have TT throttle bodies installed? I can't find any clear pictures or diagrams.
Thank you!
Nismorunner182
I figured it out. Someone put VG30 96' infiniti throttle bodies on it. WTF
elecfus
im curious about the maps they used with the stage1 modification they did. can you post pics of the fuel maps? perhaps they had plans to convert it to a turbo but upgraded the intakes first. or maybe they did some internal modifications?
nissanfreak12
Car: 92 300zx 2+2 TT
Nismorunner182 wrote:I figured it out. Someone put VG30 96' infiniti throttle bodies on it. WTF
Are you sure you are not mistaking them for the water lines? There should be 2 on each the TB, respectively one on each side and they should also have a single small vacuum on the bottom. The waterlines are like 5/16" or 1/4" and the vacuum line is 1/8" or smaller.
Just wanted to make sure.
