Totally agree........... it's a Piece of Crap!!!nametakennow wrote:You said it "reads off AFR." Where/how is it installed? At $70, I can almost guarantee it's a scam, and these exist because it's easy to make money selling crap to people without a real formal vetting process for products to go through.
All that box hopes to do is trick the Maf to bump the air/fuel ratio. It isnt a tune. It tells the Maf that i needs more Oxygen.SDspecV wrote:Ok so i got the chip..and it looks like a piece. a lil black box with two lil wires coming out of it. wires arent even copper if that matters. it also asks to be spliced into th two iat sensor wires on the harness for the maf using those quick splices. What do yall think? I dont see how any of that has to do with reading afr cause i thaught that was read off of the o2 sensor. Or am wrong. It also says that it might take up to 14 days for ur ECU to recognize it and start showing performance. Doesnt all of this sound like a bunch of b.s?
SDspecV wrote:Got a chip on its way for my spec v and since it reads off of afr and what not does anyone think the o2 sensor spacer will effect the chip in any way? If so what should I do?
