Mudvayne wrote:I am trying to set my timing. I put a rod in cylinder 1 and rotated the engine till it reaches the highest point. I am wondering do i put the button pointed to the first wire or were it connects to the rotor to the first wire.Translated to Engrish by LigouriRd at 7:56 AM 2/5/2008
You can either line up the marks on the distributor gear with the notch in the distributor or take the cap off and line up the rotor with the first point on the distributor. I typically use the latter since the gear will rotate as the the distributor is inserted into the block.
Ps: I don't believe I understood that, I was almost gonna make a crack about the flux capacitor.
