Lightforce18 wrote:never used inteli key, so you just keep the key in ur pocket and u can open the doors when ur close? How about the car is it push button start or do u have to put the key in?
You keep the key in your pocket, briefcase, purse, etc... When you approach a front door or liftgate with the key on you, you press the little rubber button to unlock the car. (Or, you can do it the old-fashioned way and press the unlock button on the keyfob.) When you get inside the car, you turn the ignition -- without the key inserted -- to start the car. You do not have to remove the key from your purse or pocket, etc....
