NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Fri Sep 16, 2005 7:29 am
here's what you do to make the KA plug and play:
pull the speed sensor, neutral sensor, and 5th gear sensors from the side of the KA transmission, put them in the CA transmission. Then all your plugs line up properly. Its so easy I can't believe this thread is still going. Honestly if you can't figure out how to do this, find someone else to install your motor!
Or use the CA lower harness and the CA sensors. WOW.
Sean
