interesting......do you have a copy of the article?tyrannix wrote:i remember reading somewhere that theres 3mm of clerance between an open valve and the piston at TDC it was one of the 'CA is a great piece of engineering' articlesthat might be why those crescent shaped grooves are in tops the pistons
Carbon buildup ontop of the pistons, slightly filling the valve cutouts???Guess?float_6969 wrote:If this was true, then why would the FSM state, all over the place, to not turn the crank independantly of the cams of "serious internal damage can occur"?
