Or have zero tone whatsoever. The stock resonator will still be in place.nametakennow wrote:The old one is welded in. The stock exhaust system is closer to 2in, so they may have to weld some kind of widening piece.
There are a lot of mufflers out there, though, personally, I think you'd be better served to get a full catback exhaust system. Just putting on a muffler may cause it to sound buzzy.
The only thing I'll tell you about welding a muffler on is you will notice almost NO performance gains and, it's kinda ricey.alfalfmarkie wrote:hahah so wat u guys are sayin is i should stop being my cheap self and just buy the ful cat back. Ok that does make sense i was thinking about by pasing the resinator but if im gonna do all that might as well get the whole nine yards. Thanks guys
That all depends on the size of the engine. The bigger the engine, the more the performance gain. Sure, an exhaust on a 2.5 might ONLY add 6 or 7HP, but an exhaust on a 5.6 Titan will add almost double that.nametakennow wrote:There would be no performance gains. Catbacks add only a little without a header, for that matter, but they do change the sound a ton.
CO-Signed. when i first bought my car (used) it had an Apexi Muffler Welded on to the stock echaust system, it was buzzy as hell. i didnt like it. i went Greddy Evo 2 and have loved the result, adding a Header is a MUST on the 02 SE-R/Spec because of the Precat break up issue. not only does it add more HP it also preserves the life of your engine by doing away with the stock header. With a stock header, your engine may be a ticking time bomb....nametakennow wrote:Any time I've heard a car with a muffler added onto the stock exhaust, it's just been a buzzy version of the stock noise. That's why I said it'd be buzzy.
NA? is 3" piping too big?nametakennow wrote:2.5in is plenty if you're staying NA.
Tell that to my Lancer when I put 2.5" exhaust on it. I noticed an IMMEDIATE drop in torque. I also have noticed on cars I dynoed in school when I used no muffler or too big of an exhaust the torque dropped off.nametakennow wrote:The whole losing torque because of big exhaust thing is almost completely bunk. The header is the only place it could possibly matter in terms of scavenging effect, and the evidence for it is wishy-washy at best.
yes, it would be a complete waste. the only people running 3" on 4 bangers the turbo folk like myself. 2.5" should be fine for your 2.5 and will go along with all the other NA bolt on stuff. You should probably measure you stock piping since that's a revised QR25 pumping out around 200hp (at the flywheel)jbarbaresi wrote: is 3" piping too big?
That was me being sarcastic. The VTEC system on Honda (which I worked with for 5 months when I worked for Rohrman's Schaumburg Honda) has all upper-end power. Hondas traditionally have very, very low torque numbers, usually just enough to get the car rolling and once you hit the "VTEC area", or about 5500 RPM+ on most cars, the horsepower takes over. The reason they redline so high is because when you shift at 8000 or so, the next gear brings you right up to 4000 and allows you to keep the powerband in the VTEC range. I know what VTEC is, I went to school for it and had to study it to work with it.nametakennow wrote:I'd love to see these dynos.
I've seriously only seen one dyno that ever showed a loss with a large exhaust, and it was 1 ft/lb at a low rpm, there were gains everywhere else.
Your butt dyno was probably fooled by the gains you get in the mid and upper range. It feels slower because, compared to the middle and top, the bottom end doesn't gain much, if any. It's the same phenomenon when people run very high angle cams. They don't lose anything, it's just the gains that are all up top.
Again, with a header, this scavenging-effect-related torque loss makes some physical sense, but with just a catback I'm unconvinced.
I'm kinda confused why you said 3" = Honda VTEC. VTEC is valve timing, and Hondas' lack of torque has nothing to do with the VTEC system itself, but with out the cams and other aspects of the engine are set up.
