quick 4wd shock question
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
4wheelsoffury
Car: 1985 nissan 720 kingcab ST 4x4 2.4L Z24
So...., is there anything special about installing some performance shocks on a 1985 4x4 sport truck? Should I just attack as normal or is there something I need to look out for ?
PEZi
Nothing too crazy. Its fairly simple to do a strut swap on these trucks. The only part I have ever found hard is compressing the shock in the front in order to get it in between the control arms, but that is not too big of a deal.
4wheelsoffury
Ran into one small glitch. On the right rear leaf springs there is a shackle that wraps around the leafs and the helper leafs. The corner of it will impact the side of a beefy shock, easily fixed by adding about 1/4" of washers to the bottom post before sliding the shock onto it. Its still really close but appears to now have just enough clearance to not ding the shock.
Return to “Datsun 720”
