Questions
burnout 180
Car: 1990 s13 180sx ca18det
Trying to get my car running on my new setup and i don't know where these things are for and where i should connect them to.
1) First what is this line for and where does it connect to?
2)Also what is this plug for i don't think it was ever pluged into anything.
jamik_69
the line i belive is a vac/boost line that goes to the turbo cap it if your not going to use it or just cp it off where it goes in to the intake manifold
and the connector looks loke its allready blocked off with one of those caps if thats the case then you dont need it
biosehnsucht
1. originally part of the variable intake system, this is fresh air hookup that goes into the intake pipe after the MAF, so when the ECU switches the butterflies from vacuum to atmosphere to open them it can pull in air from here, filtered and metered (as the air then gets pulled vacuum out via the vacuum tank to the intake manifold - this is all under ECU control via a solenoid).
if you don't hook up the variable intake butterflies to the ECU via solenoid control you don't need this. you coul recycle it to run wastegate connection from the intake manifold instead of direct from turbo (capping the nipple on the compressor, or if you have an aftermarket unit might not have to do that) if you want.
2. where is this? could be ABS sensor connetion, thats most likely what it is from the look of it, don't think anything else on the engine harness has that type of connector.
