QUESTIONS ????? On KA's
72nismo
Car: 510 / G35 / Murano
Can you put 92 head on 95 block and the car run properly??Is there anything special needed to be done for it to work.Buddy of mine did it but the car seems to be smoking.
spoolings14
Car: 95 nissan 240sx
You can put a 92 head on a 95 block, Now is the motor in 92 or a 95 car and are they both dohc? reason i ask is because depending on what car u have you will need to use the distributor from that car year.
72nismo
Car is 95.And they are Dohc.
spoolings14
ok, then your gona have to use a S14 disrtributor,intake manifold and exhaust manifold, and go with a 92 head gasket, then you'll be fine, dats a set up i currently have on my S14 right now, 93 head with a 248 exhaust cam and a 232 intake cam and it works great.
72nismo
Buddy just told me he is using that set up but when car is in idle there is white smoke and if you rev it there is alot of white smoke.
spoolings14
my car is running fine,not smokin at all and vise versa with a buddy of mine dat did a 95 head on his 93 240. well is your buddy's car smokin a white smoke or a bluish color smoke? if its minor white smoke den that should be normal considering dat its a bit cold out, and if its alot of white smoke then he may have a headgasket problem. Now if its blue smoke then he has an oil problem, possible causes could be worn rings,valve guides,bad pcv valve,or even a blown headgasket. Also check oil if its milky.
Modified by spoolings14 at 11:49 AM 2/4/2008
72nismo
The funny thing is he did the same 2 set ups on 2 cars like you and your friend and got the same problems.Smoke is WHITE>
spoolings14
well if its white smoke then here are possible causes for it smokin white: blown head gasket or cracked head, now another one would be a leaking intake manifold gasket because on the KA's the intake manifold has a coolant passage. The reason for white smoke is that you have water/coolant burning in your combustion chamber. Well hope this helps. With both of those set ups my S14 and my buddy's S13 never did have any smoke issues so i guess your buddy's car has problems and that its not the setups fault.
72nismo
Thanks for the help.
spoolings14
yup no problem, dont be a stranger ill be glad to help if u got anymore questions in the future.
j dubb
Car: guess im stuck with the s10 and dreaming about the 300zx
thanks spoolings14 that helped me too
spoolings14
j dubb wrote:thanks spoolings14 that helped me too
ya no problem, glad it helped you too.
