question about wastegates
silvia_ca18det
Car: 350whp ca18det drift silvia
i got a gt28rs and i am thinking about getting a topmount manifold, but i was woundering if it is bad to change a internal wastgated turbo to an external by just welding the the valve shut on the exhaust houseing?
does this have any effect on performance if i change it to external?
thanks allot
rob
Nowhere
Car: Suzuki x-90, samurai
What top mount are you using??? I don't know of any t2X top mounts out there??
themadscientist
As long as the welding is done properly it will be fine.
silvia_ca18det
Nowhere wrote:What top mount are you using??? I don't know of any t2X top mounts out there??
custom flange is being made and welded on! thanks for the quick reply! and yes it is going to be tig welded very nicely
themadscientist
Why not remove the flapper valve and weld a short pipe with a wastegate flange on it to the hole? It works well and allows the use on the stock manifold.
silvia_ca18det
themadscientist wrote:Why not remove the flapper valve and weld a short pipe with a wastegate flange on it to the hole? It works well and allows the use on the stock manifold.
good thinking! that sounds like the most reasonable thing to do:)
thanks
themadscientist
my warped imagination is at your service
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
themadscientist wrote:my warped imagination is at your service
Just remember to externally vent that gate !!
CA19DET
knightrider
Car: black 90 240 coupe
it can be done, like ppl say, but why? you either stick with the internal, or buy a new turbo that needs an external. no performance gains will be felt from changing the wastegate. if your just after venting the wastegate to atmosphere, you can do it with a custom elbow.
