coolbone28 »
https://forums.nicoclub.com/coolbone28-u23573.html
Sun Dec 02, 2007 9:52 pm
The fact that they are all the same and just a hair over spec means the rings are good enough to hold some boost. Ill bet that those #'s are better than a lot of the guys that go KA-T. Mileage is irrelevant. If you are still worried about it then do a leakdown test and if that turns out ok i would say boost it.
Your power goals are also going to affect if you should build up your engine.
