loyalone »
https://forums.nicoclub.com/loyalone-u151437.html
Fri Jun 24, 2011 7:46 pm
did you find anywhere to get your ecu yet? i have the exact same problem with my 01 maxima, i pulled the ecu and took it apart and found one chip in it completely exploded. my unit is number matching to yours. i found the chip that exploded for $10 im going to try to repair the board although the board looks badly burnt. if i get this to work i will be in the market to buy burned ecus, or fix them for people.
also it is very likely that the ecu is your problem, i've done a lot of research and it looks like a lot of people are having this problem, seems like especially with this ecu number. remember to replace the IAC vavle before replacing your ecu, or this will happen again. also it's a good idea to unhook the electronic motor mounts, as they can cause this same issue.
