Absolutely I would search for the best automotive AC shop and take along a copy of hte FSM and some crib notes to check if they get the correct information form all-data or just some-data.Defiant wrote:I'd leave this part of the job to an AC shop, if not even the Infiniti dealer. Some things are just worth the money.
Yeah, I think what they were really saying is that it's too much work. They didn't want to remove the expansion valve etc. I don't think he has to worry about black death since the compressor is still okay. Flushing also allows you to start from scratch with respect to the all important oil amount plus brings some peace of mind. If not flushing the evap, keep in mind that around 20% of oil resides in it. Most shops will tell you that as long as you get 80% of the oil out, you're okay. (with respect to mixing imcompatible oils)Q45tech wrote:Just shows you the ignorance of some shops as with the proper equipment you can set the flush pressure to anything from zero +1 psi to 200 psi.
Anyway the lowest pressure in the system is 28 psi which is 10 times the amount necessary to slowly flush the system.
You flush each component individually with it's nominal pressure as appropriate.
The reason you flush is to remove the black death [bits of compressor seals - orings and the inside of flex hoses and particles from dryer that start migrating around from day one in a system].
If you find black death you must REPLACE any flex hoses and compressor.
Brian,spend some time on the a/c forums,very knowledgable moderators who seem to feel the problem with trying to flush the newer design r134 condensers is that the entire internal core makeup is way different from older r12 condensers and that these passageways are so fine that trying to flush debris through them is ineffective and can create more problems than the potential ones you might be trying to avoid- no one here seems to be addressing this difference in the condenser designs and differences for the newer condensers.The newer condensers are no longer a tube/fin design,more like tiny internal honeycomb-look at the ac forums and help!maxnix wrote:The early R12 condensers and evaporators are different from the later R134a ones. Check the part numbers, including the compressor.
I don't understand the concern of solvents not being fully removed after a flush unless they are the wrong solvents initially.
Since it's R134 you can be pretty sure the design is different. Which design was incorporated on 94-96? I could not tell you since I have neither the car nor the fsm for that year. You need to take it to an AC shop so they can eyeball the condenser if you can't tell by looking at it. Use the info below as a guide on what/not to flush....qship96 wrote:the main question I have asked has yet to be answered,which is-is the 94-96 condenser of a different internal construction than the 90-93,and is it one of the types that the experts on the a/c forums feel cannot be effectivly flushed due to the tiny internal passages as compared to the older r12 compressors which had a large fin/tube design?
There is no talk of flushing because the dealer probably expects you to simply replace components. You can gue$$ why.qship96 wrote:Drew,thanks for the post-it is one of the many I have read on the subject of condenser flushing,and the reason for my concerns .the fsm makes no mention of the type of condenser in the q,however there is NO talk of flushing either the evap or condenser mentioned in fsm when describing compressor replacement or any other service on the a/c system-makes me wonder if flushing is not the correct way to go.looking at the condenser gives no clue to its internal construction type as far as i can tell.It seems my quest for this information will help other board members when their time comes,as most seem as uninformed regarding this issue as I. Considering I what I spent for a brand new oem compressor,I want to be sure the process is effective and safe to maximize my investment.
Your system is probably icing over due to low freon. Try charging it with a can first.elwesso wrote:\Im not sure though, id think running SOMETHING through it would be better than nothing, because once you open the system the oil absorbs moisture, so thatd be the main reason id wanna get all that old oil out...
I do have a question. I have a seemingly good evaporator from my old Q, the AC worked so I assume its good.. When i took it out, I cleaned itout real good with a standard parts cleaner, and its been sitting in my attic ever since. Would I be better of cleaning the one thats in the car, or installing the cleaned one?
Fraid not, had it recharged last year, and it was not low when I had it vacuumed and recharged.... Same symptoms. Whatever it is its not due to low charge.DrewQ45 wrote:Your system is probably icing over due to low freon. Try charging it with a can first.
AC system stays pretty clean unless the compressor grenaded. If you still want to clean the evap....
DrewQ45 wrote:You need to take it to an AC shop so they can eyeball the condenser if you can't tell by looking at it.
