Q45a owners... roll call
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
Ozzie's post just had me thinking. There just aren't very many of us out there... especially with Q45a's that are actually operating. It's tough to find help, even here on NICO, because the system is just so damned rare.
I thought a little roll call might be in order... it might be nice if we knew who else was out there keeping the active alive.
So post up... what active do you own? Give us some details, nothing too in depth, just the basics.
Personally, I have two of them in my driveway. My original one, which I sold to my dad, and my second one which is now my daily driver.
My dad's has roughly 150K on it and is still active...sort of. It needs the accums replaced and probably needs one of the actuators (drivers rear) replaced due to fluid leaks. Overall the system still works... just not very well.
Mine has 110K on it and is working great. Not throwing any codes at the moment (hope that lasts), but could still use some help. I have replaced the 4 accums at the wheels but really need to replace the other 5. Front and rear pressure control units need to be replaced, I think, because the car doesn't seem to control front/rear body roll very well.
Anyway... post up, peeps.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
Well, you know I have one
1990 G50.Imported from Japan.120,000 kms on the clockTiming chain guides replacedActive suspension started working again the other day, after an 8 month hiatus of operation.
I think that's it.I know there are a few people who have converted their active to a standard suspension setup. I guess that's an option if the system becomes too expensive to repair...
ceningolmo
HA... we truely are a rare breed. I think it is down to just you and I Ozzie!
I have the northern hemisphere covered... you got the south?
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
Well, there's Texasoil. he has two A's. He also recharges acumulators as a side business.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
not so fast.
1994 KL0 platinum on dove grey.110609 milesnever wreckedperfect interior9 texasoil accumsredmanfx donor multivalve unit
the active works but hydraulic system makes noises over rapid succession bumps.
more pix in members rides. need to put up some interior shots.
Hmmm, successfully linked the image with Rex's help
Modified by GQ Jay at 9:36 PM 9/26/2006
Blamecanada999
Car: 1994 Infiniti Q45
What exactly seperates an "A" from a normal Q45? Does it have air ride suspension? When I went in to have my strut looked at, the mechanic mentioned that the bill would be up over $1K if it was equipped with air ride called "FSM", "TSM", or something. Also, what's so different about a Q45t?
Macca86
Car: Nissan Infiniti Q45A 1990
Theres another in the southern hemisphere right here
Ozzie
'06 MK5 Golf tdi
Blamecanada999 wrote:What exactly seperates an "A" from a normal Q45? Does it have air ride suspension? When I went in to have my strut looked at, the mechanic mentioned that the bill would be up over $1K if it was equipped with air ride called "FSM", "TSM", or something. Also, what's so different about a Q45t?
The "A" stands for active suspension.A complex system of hydraulic pumps and actuators, accumulators, and valves to direct flow of the fluid....
http://www.autoworld.com/news/...n.htm
That may help explain it a bit better.
Macca86 wrote:Theres another in the southern hemisphere right here
Hey! Welcome to NICO!!!You appear to have the same side skirts and rear bar as me.How did you find us? Next time I head to ballarat, we will have to catch up!Australian NICO meet! (Of a whole 2 people, both Active Q's!)
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
I have one too. A '92 with 170K miles. Chain guides and accumulators recharged at my own redneck garage. It's sitting right now waiting on 2 fuel injectors (something about having the 540i bmw to drive instead that keeps the Q from getting quickly fixed). My rear actuators were leaking but I put in some Marvel Mystery Oil (think it was Texasoil that recommended that) and will see if they continue to leak. Otherwise it's rust free and a delight to drive.
velvet hammer
Car: 1990 jdm Q45a 60000miles on the clock
dont forget me.1990 Q45a 86000km'sactive has gotten very stiff on me in the last 6 mths
SmooveJazz
Car: 1991 Q45
Hello NICO,
Newbie here with flat 91 Q45A that would like to have it functioning since they are so rare. I moved to Jersery from FL about 3 months ago and need a mechanic in this area. Are there any around Edison that anyone knows of.
ceningolmo
Contact Keith Bowers (texasoil) and enlist his help. You will not be able to restore your active without it...at least, not for less than $5K.
http://www.q45suspension.com
Macca86
Thanks Ozzie, I found the site just through searching the net looking for information on the Q45... Great site here...Yeh when u come down we'll have to catch up for sure. I'd say its fair rare to see two infiniti's together down under, i have never seen one except mine...
SmooveJazz
Car: 1991 Q45
I have contacted Keith and gotten the information needed. I need someone willing to work on my Q. One Infiniti tech said he can't wait until all the actives are in the junk yard.
ceningolmo
Honestly... a lot of the essential stuff on the active is relatively easy to work on. I would take a look at some of the install instructions that Keith gives. I did the 4 accums on mine in about an hour with some help from my bro-in-law.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I dont own an active, but PLEASE, if your reading this...
DO NOT GET AN ACTIVE UNLESS YOUR GOING TO FIX IT. IT MAKES ME SICK TO THINK THAT SOMEONE COULD TAKE ONE OF THESE AND CONVERT IT OR JUST BEAT IT AROUND.
If you dont want to deal with an active Q, dont get one. there are plenty more standard Qs to enjoy, which people still cant seem to maintain.
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
SmooveJazz wrote:Hello NICO,
Why would you move from sunny Fla to New Jersey? Just kidding...
Here are some #s for your area. I'm sure if you contact them they'll help you or steer you in the right direction.
Keith Vanmeter Auto Service/Repair - Located in Mantua NJ is a reputable shop for folks in the northeast. Keith Vanmeter can be reached at(856) 415-2022395 Wenonah AveMantua, NJ 08051
Level 10 Transmissions - Located in New Jersey, offers Q45 transmission upgrades for improving performance and longetivity. Ask for Pat at 973-827-1000.
Jehangir
Car: 1992 Infiniti Q45A
I've had my active for about 2 years now. After buying it I had the timing chain and guides replaced. Then with the help of Wes and Keith I was able to replace the upper links, bushing. Next the active was throwing codes at me. So I replaced the fore/aft G sensor, and the 4 accumulators. Subsequently, my car had been trouble free until last month when I began to leak active fluid from my passenger side rear wheel. A quick call to Keith and a 15 cent "O" ring. and I'm back on the road. I can't speak for everyone but my car has been pretty much trouble free and the active has been more enjoyable and reliable than I could have ever hoped for. Again thanks to this forum.
Rex
Car: None
GQ Jay wrote:not so fast.
edit: i suck at making links to members rides.
Modified by GQ Jay at 9:43 PM 9/13/2006
You linked to the page of the picture, not the URL of the image itself
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Thanks Keith!
I swear i tried that before.... will keep at it until i can do it myself.....
cplus
i got one, didn't know until i pop the hood
Modified by cplus at 1:30 PM 9/27/2006
cabal1024
Car: 2005 Q45
As far as I know, mine is an "a". I have no badge on the rear... It's a '94 with 116k on it, I haven't gotten much into the system yet, it seems to be working though. Any help would be great. How do I check accumulators and the codes?
Modified by cabal1024 at 10:47 PM 9/26/2006
ceningolmo
BTW... a pick of my active.
ceningolmo
Anyone out there miss this thread? If so... check in please.
BTW... many updates coming. My Silver Q is now fully Active! And, with permission from Keith (thanks Keith) I will be doing a write up of Accumulator replacement with pictures... yipee!
bruce.weiland
Car: 2007 Solstice GXP, 94 Q45a, 05 G35 sedan, 01 I30, 01 X5, 95 325i
Active soon. I have been looking. Haven't found the one I want yet.
I drove a 91 and a 95 from 91 through 2001. Several cars since then. None have compared.
Just picked up a Solstice GXP, so I have a hotted up car. Plans for the Q; properly working active suspenstion, really good brakes, and a supercharger.
By the way. To you who are trying to figure out if you have an "active" suspension car, there are at least 3 or 4 tell tale signs.
1. A small "a" after "45" on the trunk lid. It is a stick on so may or may not be there.
2. A white lettered decal at the base of the rear window that says something like "Full Active Suspension". Again a stick on, may or may not be there.
3. In the car, between the center arm rest and the area where the shifter and window switches are, there is a small, rotary, two position switch, next to the CD controller in the older cars, next the seat warmer switches on 94 and 95's. It is labeled with an "N" and an "H". If your car has active, it WILL be there.
4. Under the hood. There will be a tube running to the top of each shock tower, kind of into the plastic dust caps. It is about 1/2", of slightly smaller, in diameter.
There are additional ways to tell if you have an active suspension, but these four are the quick and dirty.
Happy driving,
Bruce
bruce.weiland
Ozzie,
Here in the US, I was under the impression that all actives were 91 model year through 95.
Anyone have info about actives coming in the 90 model year in the US? If so I will broaden my search.
Thanks
Bruce
bruce.weiland
Macca86,
Your car is absolutely BEAUTIFUL! Where did you get the ground effects kit?
I don't supose you could post some more pictures, could you?
Or possibly email some to me; [email protected]
Thanks
Bruce
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Mine is a 1991 Q45a.
Parts Replaced:9 accumulators recharged by Keith (texasoil) ACTIVE Fluid A FlushFront Vertical G Sensor, Front Lateral G Sensor-1Fore and Aft G SensorRear Lateral G Sensor-2
Some pics:
ceningolmo
Lino (what's your real name, btw? And, how do you pronounce Lino? And, where did it come from?), your Active is one of my all time favorites. It's just beautiful.
Keep up the great work, man!
lino
Thanks for the compliments. You got me beat though - 2x Q45a You got mail.
