DrewQ45 »
https://forums.nicoclub.com/drewq45-u2328.html
Mon Feb 02, 2004 1:42 am
One of the beautys of this forum is being able to learn from the mistakes of others.... Here's a $300 gift for you...
I’ve done this a few times. Replaced speedo with no problem whatsoever… The 2nd time was to replace Trip bulbs…(something I highly recommend you do while you’re at it)….that’s when all hell broke loose… The speedometer can be replaced by removing the cluster and pulling the back off... Be very meticulous with every step you take since there are many parts to contend with and it’s easy to break. Not difficult but very painstaking...$hit, let me not lie…it was difficult for what I went through! Those plugs behind the cluster are a ***** to deal with especially when you have large paws like I do. BIG HINT… the entire steering column can be dropped by loosening the bolts underneath the dash (that’s what they do they do at the dealer)…I didn't consider this prior but it all made sense when the tech was talking to me.
When I last pulled out the cluster to replace the Trip bulbs, I left a plug loose (it didn't "click" in I guess) it ended up costing me near $300 bucks for that little mistake (towing to dealer + labor.. thank God no parts were required). See, I had forgotten a little detail....Not only did I not disconnect the battery, I had the car running with AC on since it was middle of summer at the time (a big no no but after downing a six pack...you get the picture). While putting the cluster back in, the car suddenly shut down. I was able to start it but that was about it… I was so sure that I had shorted something out that I had nary a thought about checking the plugs. I was thinking that I may have fried wires/circuits. The alternator had stopped charging, the AC didn't work, no lights inside the car….and a whole list of other frightening symptoms. Towed the car to the dealer and the tech pushed on one of the plugs behind the cluster to fix. To be perfectly honest, even though I left the dealer massaging my a$$, I was happy to write the check when I found out that nothing was harmed……a very costly mistake but you live and learn.
FYI, the speedo and Odometer are separate units even though they seem to be one appearance-wise. Be careful not to roll the tumblers as that would be considered illegal tampering....if you do, they will not line up perfectly again. Keep dust down to a minimum and blow out with compressed air before assembling. I had to take my whole assembly apart again just to remove foreign matter residing inside my cluster... it annoyed the hell out of me seeing that french fry sitting in front of the tach (joke).... Also, any dust or particles would be a clear indicator of someone having gone inside if I was to sell. Don't use windex on the "glass" since it's really plastic and might be etched by the ammonia. I’m sure if you search you can find the steps for cluster removal…just remember to drop the steering column too. Good luck. Sorry for rambling, thats how things are when you type long posts at work.
