loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Apr 27, 2007 11:13 am
On a 97Q, I'm trying to replace the front parking brake cable (binding problem) but in order to do so, I have to take out the SRS Diagnosis Sensor Unit under the center console area. There are 6 special bolts that need to be removed. Per FSM, these bolts have bonding agents and need to be replaced, i.e. 'one time' use only. Also, there is a stud at the center of the bolt which requires a Tamper Resistant Torx (Size T50).
Does any one know where I can get these bolts and tamper resistant Torx? I called Joe/Scottsdale Infiniti but they don't sell such items.
Thanks,Rod
04 G35 – 32,000 miles97 I30 – 91,000 miles99 I30 – 63,00097 Q45 – 92,00003 Q45 – 45,000 miles95 Previa - 75,000 miles
