Q45 Alternator?
PachoC
Last night the ABS, SLIP warning lights plus "Low Batt Charging" message on my '94 Q45A went on, and are still on. I checked the LED on the ABS Control Module; its blinking 10 times.From reading other posts it sems to be a typical case of an alternator failure.I need your help to try to precissely diagnose the problem: I used a digital volt-meter to check the voltage at the battery posts with the engine running - it varied from approximattely 17 volts to 13 or 14. Fairly unstable, though. Is this ok? Could it be the diode pack?I already checked the relays on the ABS actuator and they seem to be working ok.Any idea on where to check if the power to the ABS Control Module is ok? Where in the alternator would I find the appropriate connetor (feeding the ABS control module)?Note: the dashboard and driving lights went from very bright to dim to bright again. Possible loose connection/ground? Any ideas?Thaks in advance for your help!!
DAEDALUS
Car: 1990 Infiniti Q45
It's a pretty safe bet your alternator is going out. 17 volts is not OK, and it could be your battery is bad as well. How old is it? A lot of national chains have charging system analyzers they'll put on the car for free or for pretty cheap. I would have this done just to be certain, cause the alt is not a cheap part nor easy to replace. The bright/dim dash lights is just another symptom of a bad alt.
PachoC
Is tisafe to drive the car to have the chraging system tested?
DAEDALUS
Only if you consider the engine dying unexpectedly "safe". Not sure what the risks are if your car is running at too high a voltage though. Aside from that, it depends how far you have to go, whether you have to cross any busy intersections or get on any freeways, and whether you have a contingency plan should the car die halfway to the shop.
PachoC
I better play it safe. I am better off towing it.Tks for your help.
PalmerWMD
Car: 2004 350Z
Remember to <never> tow a RWD auto transmission car, on rear wheels.
Fred....:)
PachoC
Thanks for bringing this up. I will make sure it does not get towed on the rear wheels.
PachoC
Do you know where can I buy an OEM alternator (besides the dealer)? They quoted me $403.28. Is this reasonable?
DAEDALUS
LOL No, not reasonable. Call Scottsdale Infiniti at 1-888-216-5328. They're in AZ and will ship an OEM unit out surface for a little more than $300 I think, and then they will credit you about $70 back after you send them your old one.
PachoC
Just called Scottsdale: $307.75 + $70.00. They would reimburse the $70.00 once they receive the core back. Net price $ 307.75.Tks!
Q45tech
Don't make the mistake of thinking that ANY chain store reman is anywhere close to the factory unit........which is rebuilt to brand new specs.......many times you get a brand new unit!
Pretty inexpensive for something that will last 80-120k.
Always replace your battery if over 2 years old as a bad uncharged batttery will take years off a perfect alternator life and usually destroy a cheap remanned one in a month [especially in summer].
PachoC
I would definitely stay away from chain store reman; that's what all other posts clearly advise.One last question (I hope): Could a weak battery (435 CCA instead of 700 CCA) cause similar symptoms?Note: I had the battery tested last night and in theory needs to be replaced, but I had already ran the car for 15 to 20 min with the "Low Charging..." message on.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
An under OEM rated battery will put more strain on the alternator.
Change to over OEM rated battery while replacing the alternator.
