q45 1991 power ant.problem
q45 1991 infinite
Car: 1991 q45
need your help.My 1991 q45 210,145 miles, my power antenna stopped going up and down. Its stuck in the up position. I can hear the motor whenkey is on,as if its going up and down. motor is working. Why could the antenna be stuck? I think you guys are great. thanks, keith
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Try a new tail first. If that doesn't work, you will have to get a moeotr assembly.
qship96
Car: 1996 Infiniti Q45
I think Brian was attempting to say try getting a new mast first and install into present motor assembly after cleaning out the old one,if that doesnt do it,order whole new assembly.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:I think Brian was attempting to say try getting a new mast first and install into present motor assembly after cleaning out the old one,if that doesnt do it,order whole new assembly.
Exactly. The teeth in the tail of the antenna usually wear out first. If the drive gears are worn, then one needs another motor.
Whenever I see a G50 with a stuck antenna or a cheapo fixed replacement, I know that owner doesn't care about his car. There are a couple of posts on replacement.
q45 1991 infinite
Car: 1991 q45
Ill try that. Thank you very much.
