moso »
https://forums.nicoclub.com/moso-u137641.html
Sat Mar 05, 2011 9:33 pm
sounds like your not getting power at the ecu. check your fuses, all of them, it sounds like you blew out a fusible link. if you list all the things that don't work I could probably narrow it down to which one it was but its probably easier to check them by removing them and testing for continuity between the terminals, its not good enough to just check by eye. if that doesn't help post a list of the things that do/dont work and i will try to help you narrow it down. is your 240 se or base, us or can?
