bruno305 »
https://forums.nicoclub.com/bruno305-u158123.html
Fri Apr 09, 2010 10:24 am
the rims in the front of my g35 is rubbing the brake pad...what size studs do i use when putting longer studs the 50 mm or 60mm ???or do i even need studs?? the screw is not going around 7 times like it needs to be closed..what should i do ??
