lego126 »
https://forums.nicoclub.com/lego126-u171829.html
Fri Mar 23, 2012 6:39 am
I wanna put a A/C into my 85 720, which was never installed. Luckily I live just a few miles from a pull a part, and most of the things I'll need will come from there. The thing I know I need, the basics, Compressor, condensor, Evaporator, Fast idle solenoid, and hoses. There is not a Accumulator on my later 97' model but I'm prob gonna hook it up just like it is in the book. I've traced all the wiring diagram in the haynes, and sseen how everything is hooked up, but I'm not sure I need all everything that it says. Has anyone ever attempted to put a a/c into a vehicle w/o one? Will I have to hook everything like it says, or can I just put it on a toggle switch and flip the switch? The switches /relays inside the cab are, A/c relay, thermo switch, compressor switch, and A/C warning lamp, and under the hood is a Low pressure switch. I guessing the compressor switch is just the A/C button that you push the turn the A/C on, and the warning lamp is the little light that lights up. So that leaves the A/c relay, thermo switch, and under the hood Low pressure switch, I'm pretty sure on earlier models is on the accumulator. So can anyone help me out and give me some advice?
