90Q45blue wrote:If you can give a 100% guarantee that every oil filter you use from now until the end of the car's life will be 100% in perfect working order during the entire time of use, then I guess you don't have to pull the pan.
But since no can give that guarantee, I would pull it.
Nick
Everything went well until I got to pulling the actual suspension crossmember. I just can't seem to get it to budge.
The engine is supported and the nuts holding the motor mounts to the crossmember are off. The two outer nuts on both sides holding the crossmember to the frame are off. The middle nut looks like it doesn't have to come off, and I would have to pull the lower suspension arm to gain access to that third nut. There seems to be a hole in the crossmember and the nut doesn't appear to attached by that nut. Is this my problem?
Also, the four bolts holding the steering rack to the crossmember ard off and the rack can be pushed aside. The front sway bar has been removed as well. All of the wires and hoses and/or steel lines are loose. I have pulled the four bolts on the transmission holding the strengthening brace that brackets the engine and transmission. I have not taken off the bolts from the engine; they are very difficult to get at. Could this be my problem?
The car is supported on the frame rails on each side by a tier of three railroad ties to allow the wheels to be free. That should allow the crossmember to be lowered even though the strut brace and lower control arm are still attached. Would removing these sove my problem?
I'm stuck and I was hoping to get the oil pan off tomorrow so I can actually replace something instead of taking it apart! You should see all the boxes of stuff in my garage. ALL WORDS OF WISDOM GREATLY APPRECIATED.:help
