Project S14 2JZ
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
Kalypso
I hear that, nice work bro - im excited for you
godzilla-32 wrote:Great build Mate.
Where did you get your engine mounts from?!?i'm currently doing the same thing to a skyline and i can't find mounts.
Use the stock supra mounts and custom fab some plates to your existing cross member.
godzilla-32
Car: r32 gtr vspec II
any pics?
Kalypso
Acidz im sorry to blow up your thread, if you'd like I can delete these later.
godzilla-32 wrote:any pics?
....here you go, I cant believe I found these.
this is how it should look... for a 2jz into s13... you can either slice the nubs on the crossmember or build up on top for a husky v8.
its that simple bro
godzilla-32
that doesn't look simple at all...
wrxratd
Car: 1990 240sx hatch, 2002 WRX
godzilla-32 wrote:that doesn't look simple at all...
Anything worth it usually isn't.
Acidz
Car: 1995 Nissan 240SX w/2JZ
March 22nd 2009------------------------
Getting there boys!!!!
starting to put everything back together as in bolting everything down and making it final!!! don't wanna put anything out again....Also got the intake mani done with plugs and also my 3.5bar map sensor put into it.
also got another line done the the fuel system in the back finishing off the feed for the A1000 pump for the cell & oil cooler lines and oil filter all bolted in and finished
the last thing done today was the bender stand...havent placed it in the floor yet due to the car being where we wanna place the bender and having it so we can remove it when needed.
godzilla-32
sorry mate.
thanks heaps for the pics. it just seams a bit dawnting at the moment...
cheers tho.
matafied
Car: 1989 240 rb25det 1992 240 rb25det
looking awsome. loving all the quality parts
mexicanracer03
Car: 95 S15FRONTEND SR20DET and 97 2JZ GT4294/ 93 SC300 Black/ 95 SC300 Green
Acidz wrote:March 22nd 2009------------------------
FYI : JUST PUTTING IT OUT THERE THE CAR IS UP FORSALE!!!!!!
As you can SEE This is GRADE A++ work. No mickey mouse crap.
For Info you can contact : Rene Rebelo
Rene if you want I can delete this but let me know. Bro
Acidz
April 04 2009---------------------
The car is sorta on all 4 for now as i have someone that’s coming in that needs all 4 fenders rolled....i bolted up the set of te37s i have via my buddy. Well kinda comes out a bit too far, but that’s also with a 20mm spacer behind it....i plan on mounting my tires on my rims within the next 2 weeks or so.
Anyways rear seat delete was all covered up with black suede to match my steering wheel just need to finish the mid section. The cry02 bottle was also mounted + trunk lip bolted back in. The turbo, exhaust, dump tube and wastegate was all put back in and bolted down. Fuel lines under the car were all bolted to the bottom and cleaned up all nice....anyways pics i dont have a lot for this update sorry....
Kalypso
I will have closure once its all back together and we get an outdoor photoshoot.
Acidz
April 8th 2009--------
not much done, but i now have my fuel rail return lines and the intake manifold put in along with the hot side ic pipe! looks like i should be starting the car up for the first time on saturday!!! hope everything works....friday and saturday morning i will be putting the final things together to get the car up and running then its just the small things to finish the car off....can't wait..
Acidz
April 12 2009---------------------
well boys.....we are deff getting there! last night i ran out of -10 fuel line so i couldn't finish off the 2 lines in the back, but i hope to have that done this morning and if i'm lucky have the car started sometime today. anyways ill leave you all with the pics until i have more....
Happy Easter everyone!
Acidz
April 13 2009----------------------
So i started the car on April 12th Easter sunday for the first time and well boys everything went well!!! i loaded a base map and the car started first shot! I love it i couldn't be more happy then seeing it all come to life for the first time. Now the next step is to just get everything all cleaned up and put in place then head out for the tune.... had a but of smoke everywhere from everything being new and also didnt have the exhaust flange lined up 100%
o and i didn't forget the vids!!!!
http://www.youtube.com/watch?v=vXhiv_4LiUw
http://www.youtube.com/watch?v=WthzCq57BOk
http://www.youtube.com/watch?v=T2faz3j_ktA
Kalypso
nice work
Acidz
April 14th 2009-----------------
http://www.youtube.com/watch?v=qmwIhSJcVfM
http://www.youtube.com/watch?v=_3U9TCELVFk
2 more videos with a small tune file i had sitting around and Don't mind all the talking and excitment in both vids!!!
Kalypso
whats different about this 2nd 2j tune
Acidz
i have a map from another 2jz that has some of the same s***
Acidz
April 19th 2009------------------------
nothing much took some time to take pics of the car out in the sun! anyways put the carbon hood on and thats about it.....lol
matafied
WoW! very very cool. cant wait to see some numbers
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
very nice
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
I'm late to the party but let me just say damn nice build man! You are an inspiration to engine swappers everywhere! Talk about a DIY'er. I'm completely impressed and wish I had half the skills and talent you have.
cobra tom
Car: 2003 turbo cobra
Acid what size rear tires and wheels are on your car?
Acidz
May 3rd 2009--------------
well....i got some updates got my rear brake setup all worked out now just need to get the bracket done is metal as we made it out of wood for testing we also put new peak performance 60mm studs all around as the old 60mm studs were s***. not only did we upgrade to better studs we also upgraded the rear spindle to 14mm studs we drilled out the old holes to take 14mm studs all around anyways pics!!
calipers are gonna be painted black to match the front. also rear rotor is 13"
Acidz
May 5th 2009--------------
Updates!!!
Acidz
May 7th 2009--------------
The pics of the car are from monday...the car really needs a wash its dirty like crazy!!!! hasent seen a wash in a very long time anyways thats some pics of it looking good lol also wired in my aem uego gauge into aem and my boost control. after all that was done i put aem back in its place and also installed my passenger kick panel along with the JDM flare lol
Kalypso
your car rocks bro,
this thread is a 2jz s chassis encyclopedia, I'll be back long after your gone to learn more from your work.
how can I learn to plot a fuel system like yours, ( i know you cant explain it all here ) and whats the total amount of gas you can carry now?
Acidz
Kalypso123 wrote:your car rocks bro,
i dont know how much gas it can hold i have stock tank plus a 10gal fuel cell...
Acidz
May 16th 2009------------------------
I have updates
1. Custom Hydro E-brake setup2. wilwood brake bias 3. Calipers painted black4. rear brakes completed5. air filter for turbo6. custom bung welded into filter pipe7. reworked a bit of wiring
we did a lot today and it's great im just happy the hydro setup we did is now finished and fully working with the big brakes out back. Next step from here is the cage which i hope we can get started on tmr. Well ill leave you all with the updates until next time.
More updates coming soon!!
Modified by Acidz at 12:13 AM 5/17/2009
Kalypso
keep rockin
Return to “Hybrids”
