First thing it needed was the carb gone thru... The ad said it needed a fuel pump and a few carb adjustments... ya, right... I ended up doing a complete overhaul since it's been sitting for years and there was no way gas could even get into that thing, inside the carb was bone dry and all the fuel passages were totally blocked.
Carb fixed but running rough as hell... new plugs and wires fixed that little problem.
Nothing works electrically... Lots of spark chasing and un-butchering the wiring to get the headlights, horn, and signals to work again... Thanks for the links to the wiring diagrams, they helped a lot.
The cab didn't match up with the bed... I found that the body lift kit was missing a spacer at the passenger's side rear corner, and the driver's side rear spacer was just sitting there not even bolted down.
Heater didn't work... more spark chasing, found the problem to be a bad ground... now it's nice and toasty inside
Took it for a few more test drives today to make sure it would go thru all 5 gears and to make sure the 4 wheel drive worked... all is good there.
This thing is in desperate need for some new seats since a leaky sunroof ruined the bench seat on the passenger's side and the sliders are rusted solid... My plan is to borrow the seats out of my 300zx and install them into the truck since they'll bolt right in... and this gives me an excuse to get new racing seats for the Z too... lol
While I'm doing the seats, the interior needs some freshening up as well... The dash is cracked but those dash caps look great when installed properly, a little vinyl dye will also bring the plastic up front back to life... and a new carpet for this thing is another cheap upgrade. The only thing I'm gonna have some trouble with is the headliner, I've done several of them in the past but never this type that has the support ribs.
The body is nice and straight except for the front valence and another dent in the roof causing the sunroof to leak it could also use a new front bumper then it'll be ready to prep for paint
Here's some pics of it after I got it home... I already had the carb off, overhauled, and back on before I could get a good set of "before" pics under the hood... Hopefully I can get the interior done in the next month or so and be ready to paint it as soon as the weather gets a little warmer over here...
