fixed, thanksnametakennow wrote:What year SE-R?
well actually we did that , i got a new one from the nissan and had them install it. and it lasted around 6-8 months working properly but now is doing it again. i had to replace the crank sensor, but still does the safe mode and now even while driving. so the tech said that the next thing we need to replace is the harness. that like 680 harnes plus 4 hours of labor. to much money for me to put in the sentra. ill guess ill stay like this...nametakennow wrote:^Good call.
I doubt the two are related. The TPS is integrated into the TB on B15 SE-Rs. It's a common failure and somewhat expensive due to said integrated design. If it's reading incorrectly it could cause the ECU to go into safe mode. Might be able to find one out of a junkyard for cheaper.
Just to clarify, what did you replace?EL MAMITO USMC wrote: well actually we did that , i got a new one from the nissan and had them install it. and it lasted around 6-8 months working properly but now is doing it again
first was the Throtle body,at the dealer ship in YUma. then about 2 weeks ago here in NM, i took it to get program again the TB. and they said that the code for the tb was not showing but yes one for the crank sensor. so i went buy it and installed my self. took it back to nissan to erase the code. and like not even 10 mins later the car started again with the rpms idle ing at 1100rpm and then going up and down to 1800rpm . so it like old cars when the tps is bad that the rpms raises and lowers it. and creates a bad iddle. thats whats happening to the car.nissangirl74 wrote:If I were you, I'd check on someone besides the dealer working on the car. Their hourly rates can be stupid expensive and turn a manageable repair bill into a financial nightmare. $60-$100 per hour is way too much IMO. Just to clarify, what did you replace?
i just change it..nametakennow wrote:IIRC the crank sensor was a recall on some of B15 SE-Rs. Doesn't really explain the idle fluctuations, though it would explain the safe mode.
Idle fluctuations could simply be a vac leak as well. TPS seems more likely.
