Problem with rear brakes
grip1968
Car: 2000 Nissan Maxima
I changed my rear brakes & rotor on my 2000 maxima GLE, now when a pull the parking/E brake up, the car still rolls when i put it in drive. Is there something in need to tighten up. it wasnt like this before i changed the brakes & rotor....
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
The Parking Brake has a mechanical linkage that splits into left and right cables for the respective rear brakes. Make sure the linkage is good and that the mechanical connections on the rear brakes are secure.
grip1968
I think the linkage is gd i put everything back like it suppose to be, also i notice that when i have the rear wheels jack up of the ground, they spin way to freely is that suppose to happen. cause before it had a lil give to it, what mechanical connections you talking about???
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
If the parking brake is not engaged, then the wheel should spin freely. If the parking brake is engaged and wheel still spins freely, there is something wrong with your connections. Please refer to the link below, especially pages BR-30 and BR-37
http://www.nicoclub.com/FSM/maxima/2000/br.pdf
grip1968
when i pull the parking brake up the wheel do spin freely, I also notice that when i pull the parking brake cable up the spring that pulls the cable by the caliper go all the way down. is that normal. if not how can i adjust it..
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
Please refer to the earlier link for illustration. The main adjustment is on the Parking Brake lever on the console.
grip1968
yes i thighten the parking brake lever, but my wheels still spin freely when the parking brake lever is engaged. im clueless of why this is happening.
jaxmax
Car: 2001 Maxima SE 5 spd
Grip, If they worked fine before you did the brake job, then it almost has to be they way they were reinstalled. I doubt its the cables out of adjustment. If you have the time, sit in front of them and take them back apart, are you using a manual? If so double check everything you did and if it doesnt work itself out take some pics and post them. The guys on here are good and may be able to see something wrong.
