J-Owner »
https://forums.nicoclub.com/j-owner-u3840.html
Thu Apr 05, 2007 7:53 am
Are you saying you are having problems filling up the tank completely?
If so then you may have an issue with the valve sensor in the neck of the tank. This has ocurred occasionally on the '05 coupes and happened to me. The replaced my whole gas tank and that alleviated the problem but this was before they knew about the sensor issue. Have the dealer look at that.
I am not certain but I doubt that it is a gauge issue. It is more of an issue with the sensor that tells the tank when it is full or in your case when it thinks it is full and in actuality it is only half full.
Like I say I hope I understand what your asking correctly. If not then sorry.
