JDMSIL80 »
https://forums.nicoclub.com/jdmsil80-u30772.html
Tue Aug 16, 2005 5:34 pm
I was about to pick up my car today from the shop, only to find problems with the brand new Garrett GT28R that I bought.
When we started up the car and let it idle, there is some clinking noises coming from the turbine. Give in more gas, the clinking noises gets more frequent and louder!
Couldn't figure out what it was at first, because the turbo is spankling new with no shaft play what so ever.
We took out the intake pipe and found the problem, the inlet turbine wheel is actually grinding slightly against the housing. You can only detect this problem only when the engine is running causing the wheel to spin, the noise is not there if you only spin the wheel with your finger.
So without taking the chance I request to have the turbo taken out again and have it re-built. More money down the drain!!
What pissed me off is the turbo is brand new, I spent the extra money for peace of mind, but now only making more problems!!
And what are the freaking chances of a faulty turbo from Garrett? Is it just my luck or what?
Let me hear what you guys have to say, Im so confused.
