probelms with 02 spec V
xtrcarracer
Car: 2002 Nissan Sentra SE-R Spec V
It seems that I have somewhat of similar probelm from what I have been reading in the thread.First my car has 71,000 plus miles on it.Second its been out of commision for three weeksI have mechanics trying to figure out what the probelms are and they are clueless.Here are the symptoms I turn on my car and then all of sudden its dies on me with the key past ignition. Secondly I get a diagnostic at the dealership they say its my fuel pump or the timing chain my mechanic says that can't be since there is no spark, no gas, and no pressure, It did turn on briefly by switching the ignition switch but just for 5 minutes before it died my mechanic. He didn't want to come to a conclusion that it maybe the computer. But I need some help with this situation.
redtop240
Car: 92 240 RB20 Coupe
Did you ever have the recalls done on the car. The two big ones were for the TPS sensor or the crank angle sensor being screwed up and causing the car to die. The second is for the ecu recall. I had the 02 at one time when it first came out and had similar problems till the recalls were done. Hope that helps. Also I have a Hotshot header for sale i will part with it for $200. I paid $359 brand new for it. It frees up so much power.
