Pressure Leak?
hacyec
Car: 91 300ZX
Hey guys, I finally found this pressure leak that's been bugging me for some time now and may be the cause of my rough idle (hopefully!). On the passenger side of the balance tube air is heard being sucked in. Would this cause rough idle?
armywill84
Car: 1995 nissan 300zx N/A 2+2
open vaccume; check all vaccume hoses for leaks and disconnections. Also there are little rubber seals that are on the intake to help seal the balance tube, and make sute the balance tube is true and not bent.
hacyec
Car: 91 300ZX
So fixed the leak, apparently there was a bracket that I put back under the balance tube instead of above. How else can I check for leaks in a cheap way? The engine is loud so it's a bit hard to go at it by ear alone, I got lucky with this one because it was really loud.
es.biggs
Car: 1990 300ZX 5sp NA
hacyec wrote:So fixed the leak, apparently there was a bracket that I put back under the balance tube instead of above. How else can I check for leaks in a cheap way? The engine is loud so it's a bit hard to go at it by ear alone, I got lucky with this one because it was really loud.
I did that exact thing when I changed the spark plugs. Scared the hell outta me for a little bit because it wouldn't run, then I realized what I did...and DUH. haha
hacyec
Car: 91 300ZX
Yeah, that's when it must have happened, when I last did the spark plugs lol.
hacyec
Car: 91 300ZX
armywill84 wrote:open vaccume; check all vaccume hoses for leaks and disconnections. Also there are little rubber seals that are on the intake to help seal the balance tube, and make sute the balance tube is true and not bent.
Hey guys, what would be the ways to check for leaks besides listening? I came across this tonight:
http://www.boostpro.net/guidesz32basic.html
but I don't have an air compressor. Do those ultraviolet kits work for our cars that they sell in autozone?
