pressure in gas tank
driftaholic
Car: '91 Nissan RM S13
about half the times i get gas, when i open the gas tank, it makes a sound like air rushing in, or air rushing out, not sure, but there's uneven pressure in there. what's the deal? i had bad pcv valve on my old truck that had the same effect on the pressure in the gas tank. is that it? or is it something else?thanks
Mayhem_J30
Car: Ummm...My Car
i believe that means your tank is working properly and holding pressure preventing harmful fumes from leaking out and into the environment.
driftaholic
so that's normal? do all normal gas tanks make that sound about half the time? i've never heard of that before
240_Keyy
Car: '90 240 Fastback
Yeah, Mine does the same thing, cept when it gets really pressurised gas starts POURING out of my charcoal canister. Anyone have any ideas about this?
Mayhem_J30
Car: Ummm...My Car
240_Keyy wrote:Yeah, Mine does the same thing, cept when it gets really pressurised gas starts POURING out of my charcoal canister. Anyone have any ideas about this?
ooo..that can't be good. that's a possible explosion waiting to happen. get that fixed soon man!
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
Mine does this everytime I get gas.. it even has a little label on the gas door that has a brief explanation about the pressure. Because of that I have never thought twice about it.
driftaholic
oh a label!that would be handy.previous owner must have lost my label.thanks
PMan_S13
Wow, I actually helped someone with a problem rather than asking for advice about one of my problems..
I guess we all have to start somewhere! :D
240_Keyy
Mayhem_J30 wrote:ooo..that can't be good. that's a possible explosion waiting to happen. get that fixed soon man!
Dang ol dang! Everyone tells me that I should get it fixed, but how the fook do I fix it when I have absolutely no idea why it is happening in the first place? :confused:
Does anyone have any idea what this problem could be?
driftaholic
for something like that i'd go to a shop right away. screw fixing it yourself, man!
240_Keyy
Never again will I take a car to a shop.
Ever. (well maybe for alignments)
Unless it is a brand new car and is still under warranty I refuse to take a car to a dealership. Especially in this college town all of them will totally ream you up the butt without any lube whatsoever. I have a shop of my own that has just about everything except a hydraulic lift, so doing the work myself is no problem whatsoever, I just need to know what the problem is. Oh well, maybe I can just deal with it for now and then delve further into it whenever I get my SR from Dauntt (which will be swapped by me in my shop)
so there is still no idea what is going on with this? And to add fuel to the fire, the tank will also pressurize if the car is sitting in the sun with the gas cap on, I came outside one day and there was a long trail of gasoline running down my driveway and pooling up in the gutter things :) As it sits now, I have the gas cap on bu not tightened down.
driftaholic
i've had to bite the bullet and go to the dealership a few times, just to find out what wrong. but then i'd go home and fix it myself. about $100 to hook it up to the computer and diagnose it, but then you save on parts by not having to guess and fix things that weren't broken, plus you save time. i agree though...i try to avoid shops whenever i can!
scuba_sean
Car: snowboarding, sailing
ok, the gas tank has pressure in it to give it a boost of pressure going into the fuel rail. my friends avenger wouldnt run one time because the gas cap wasnt tightened enough and there was no pressure.
Queamore
Car: Cars.
I belive that pressure in the tank is a good thing. It lets you know that there are no leaks and it is very normal. just turn the cap slowly and let the air out first when you gas up. I belive it builds pressure because of the gas return from the engine so the harder you drive it the more pressure you will build up.
driftaholic
thanks guys. this is all good stuff
b240
I know this is off the topic , but i was born in hayward driftaholic...how is it there?
driftaholic
weather's okay, didn't have to wear a jacket today. other than that, lots of raiders fans running around being crazy like we won or something. well i guess they do that even in the off season lol.where do you live now?
slw240sx
Car: 1990 Ca18det 240sx Hatch
my friends lasaber, had that problem with the charol canister! n he ended up with a hughe fire ball comming from up under his hood it blew up the whole corner it was in all he needed to do was relplace a valve and the canister.. it has a stuck valve in it or somthing its been like 2yrs since we did this repair so i forget what all we replaced, all i know is this kid is a complete dumas s and he fixed this problem nearly on his own so it shouldnt be that hard !
240_Keyy
so the canister itself it the fubared part? If so then I can just get another canister.
slw240sx
it might be! i was just hangn out with the kid who had this happen and i forgot to ask him bout it ! im pretty sure all he had to do was replace the can !
