jt15833 »
https://forums.nicoclub.com/jt15833-u30482.html
Tue Sep 30, 2008 7:00 pm
Just installed the nismo regulated and smoothed out the bores of my fuel rail a little bit which fixed my leaking issue. Now there are no visible leaks, nor are there any leaking noises once the pump has finished priming.
how I have been adjusting the regulator is turning the key on til the pump primes, adjust the nismo unit, and keep repeating until 36 psi. I am not sure how much pressure drop should be expected, but I am down to about 30 psi once the pump has finished priming, and 10 psi after 5 minutes. This seems like a bit to me, but I do not know how the regulator operates once the car is off and if it supposed to drain this back into the return.
That pressure drop seems like it would be a bit of fluid, and I have adjusted and readjusted my nismo a few times, yet no visible sign of liquid fuel. I may just be paranoid from my leaking injectors but i do not want to leak fuel! Any input welcome.
