2008AltiCoupeDan wrote:if ur prewired, just stick the pos/neg terminals into the other side of ur fuse linebox thingie and viola, but u will need the stalk to turn them on lol so yes- u can easily install them and they will run w/ the wires to ur alternator/battery and u dnt have to set a separate relay or fuse.
This is a really confusing post because its worded in forum-speak.
If you are pre-wired for fogs, you will have the jumper wire already in the fuse box as shown above. This also means that you will have the plugs already hanging somewhere near the foglight openings behind your bumper, they might just be taped up to the rest of the harness.
Thus, if you are pre-wired, you can purchase the combination stalk/switch intended for vehicles with foglights. Installing this stalk will automatically energize those spots in the fuse box. Then all you have to do is install the fogs and plug them into the connectors on the harness.
If you are pre-wired and do not want to purchase the combination stalk, then you will have to install the fogs just like any other auxiliary light with its own switch or tapping it into the headlights or parking lights.
If you aren't pre-wired and do not want to purchase the combination stalk, then it is the same situation as above.
If you aren't pre-wired and do purchase the combination stalk, then your fuse box will be energized. Then you can run one power wire (12-16ga) from each fuse spot 86 to one fog light and one power wire from fuse spot 87 to the other fog light. Then, ground each of those fogs where ever convenient and you are good to go.
