Power Window Problems
cobb_cruiser
Car: Infiniti G20
I couldn't find this particular problem when I searched the forums, so here it goes:
I have a 2000 G20 and all 4 power windows work -- the problem is that not all of the switches will control the windows. I can control the driver and 2 rear windows from the driver's side "master" controller. The passenger window will only work when using the passenger-side switch (the driver-side master controller will not operate the window). Neither of the 2 rear window switches will operate the rear windows (they only work from the driver-side switches).
I checked fuses and they are all fine. Any help would be greatly appreciated!
nametakennow
Car: '06 MINI Cooper S
Sounds like the switches themselves are busted.
cobb_cruiser
Car: Infiniti G20
Ok, that's what I was afraid of (I was jut hoping that there was a simple reset switch or something like that). Thanks for your reply.
maddog4509
Car: 2000 Infiniti G20
Cobb_Cruiser:
It seems like I have a pretty similar problem as you on my 2000 Infiniti G20. I can operate all 4 power windows from the driver control panel. The rear windows and passenger side window switches, however, do not work. Have you had luck yet repairing this problem?
Thanks.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Had the same issue with my old G20. Find a junkyard special and replace it.
cobb_cruiser
Car: Infiniti G20
Hey maddog4509,
Hadn't done anything yet since I was on vacation for the past week. I will probably go to a junk yard as RED_DET recommended. Hopefully I can find a G20 around. Good luck to you!
