power steering
A home for 1983–1989 300ZX owners!
neda240sx
Car: 1991 SE fastback
i have an 88 300zx with a ps leak. first it was the high pressure line. as i was replacing this i noticed a second leak coming from the steering rack housing. realized it was the (o-ring) or (oil-ring). as i removed the steering arm or joint i noticed i needed a special tool to remove the rear housing lock nut and rear housing cover. i need to know if i can use another method of removal or have to use these tools and if so where can i find or purchase them?http://s930.photobucket.com/albums/ad14 ... age001.png
Murdered_T
Car: 1979 Datsun 280ZX byach
You can pick them up at your local hardware store. There pretty cheap.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
before you tear the rack apart, are you running dextron type atf and not regular power steering fluid? these call for dextron type atf, regular ps is too thin and leaks out, simply running the correct fluid might resolve your issue, and if you are runnign the correct fluid, B&M trick shift is a bit thicker and can help to slow the leak
neda240sx
ya ill give it a shot thanks
Return to “300ZX (Z31) Forum”
