ezflow »
https://forums.nicoclub.com/ezflow-u45427.html
Mon Jan 15, 2007 9:13 am
You can pay a dealer to flush it, I am not sure it's all that necessary if you periodically refresh it by taking a turkey baster and sucking out all the old fluid in the reservoir. I would leave a little at the bottom so no air gets in the system, but it will likely work itself out as you drive even if it did. Refill with fresh factory fluid, or an equivalent. I think Valvoline makes a semi-synthetic PS fluid that's supposed to add some life to the system. Make sure it's compatible.
