Power steering fault
dannyfiveforty
Car: 1992 UK Z32 300zx twin turbo manual
My 1992 300zx twin turbo, has a problem when the car drops below about 30mph the power steering stays hard. If I turn the engine off and back on again it's fine again until I drop below 30mph again.
If I plug consult in and go for a drive I get no speed reading from the ecu, but the speedometer works fine...
What could the problem be?
Thanks, dan
frapjap
'07 Subaru Legacy
Welcome to NICO, Dan!
Thats an interesting problem alright.
Silly to ask, but just want to cover the bases- have you checked the condition of the fluid? Is it low, dirty, etc?
Is the power steering hard when you try to turn the wheel from a stop?
My guess is that its either low on fluid, needs a flush, or the pump is on its way out.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Totally agree with the above, most likely low fluid or bad pump.
