Powder coating Plenum?
emiliog2276
Car: 1990 300zx 2+2 NA
2002 Nissan Sentra GXE
I was thinking of powder coating the plenum. My question is do the throttle bodies need to be removed for this procedure? If so do the gaskets need to be replaced?
Sgt
Car: 1991 Fairlady Z (JDM) Twin Turbo
Yes, remove everything from the plenum. Powder coating requires spraying a powder (duh) on the metal. After that it is baked on at high temperatures. If you left the throttle bodies on, that would f*** up the butterflies.
When I powder coated my plenum, I replaced all of the gaskets (throttle bodies, lower plenum to upper plenum gasket, IACV, balance tube O-rings, etc). They are cheap and it is not worth all that work just to find out a gasket is shot.
REDWINTERZ
Car: 1994 Nissan 300ZX (Aztec Red with Black Leather)
And his is BEAUTIFUL if you haven't seen it...
SilverTwin(OH)
Car: '91 300ZX Twin Turbo
You will also want to tape off all of the gasket surfaces during the powder coating. You will also save yourself a lot of frustration by plugging all of the bolt holes to prevent the threads from filling with powder coating.
Any quality shop will be able to handle this for you.
Make sure the inside of the plenum is clean prior to powdercoating. If there is oil residue in the plenum from the pvc's, it can come out during the heating process which will mess up the finish and adhesion of the powdercoating.
Sgt
I spent over 40 hours sanding and grinding all the casting marks and those chunks you need to grind to remove the injectors without a plenum pull. Sanded it smooth too. When I got it coated I made sure to specify which faces and holes to cover. You can't really tape it off yourself because they dip in in an acid first to remove contaminents.
Thanks redwinterz
emiliog2276
Any specific liquid i should use to clean inside the plenum or just regular water with any cleaning solution should be fine?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
REDWINTERZ wrote: And his is BEAUTIFUL if you haven't seen it...
Pics or it didn't happen
EDIT: And make sure you use a penny too or it also didn't happen!
Sgt
Ace2cool wrote:Pics or it didn't happen
Ace2cool
Oh. Wow. JUST NOW realized you were RHD. And yes, that looks awesome. Never been a fan of a red plenum, but yours looks pretty good to me.
I don't see a penny though....
Sgt
Haha thats from the summer before it got cold and miserable outside. My car is 3 miles away in a garage. I used a pic I had on my comp. Haha
