so now that I played with the vacuum hoses (all of which were plugged in the right place before I started the car again) I start it and it still has the same idle problem. so I figure I'll just play with the air idle control valve when I get to school and adjust the screw. so as I am starting to drive everything is acting normal till all of a sudden about half way through first gear the car bogs down hardcore and I lose all power and speed, and it doesn't respond when the accelerator is floored. but it went through second gear just fine. so after quite a few slow slow starts the problem seems to go away and only happen occasionally.
well tonight on a quick grocery run the problem returns with a hardcore vengence. it started losing power in all gears not listening to the throttle, and slowing me way way down almost causing a wreck.
anyways sorry about the super long story time here. I need help! I have no idea what could possibly be wrong and I am seriously at my witts end. if you have any insights on this problem please respond to this post. the more experience you have with these cars the better. I want to know what is causing me to suddenly and at random lose power and why the car refuses to stay idleing. I even tightened the throttle cable up pretty good that's probably the only reason it idles some of the time when it is warm (at about 1500 to 2000 RPM's)
anyways thanks in advance
