POOR BRAKE PEDAL
luckyz17
Car: 12 titan pro4x
04-sc xterra se
04 z roadster
Squishy pedal post brake flush, master cylinder replacement, ft and rear pads and rotor replacement. abs module ?
longtooth
Car: 89 d21 HB
Nothing electric will give you that mushy pedal. You still have air in the lines or that master cylinder is weak right out of the box.
Q451990
Does the ABS have a bleeder valve? Some do and some don't... Check the FSM (available at www.nicoclub.com/FSM/ ) to make sure you followed the correct bleeding order.
Good luck!
Heath
