Plug Wires
Lakehimself
Car: 1991 D21 Pickup
I had a 2000 jetta that I put 10.3 mm plug wires on and I totaled the car so I took the wires off, and just out of s***s and giggles I put them on my 91 hardbody, does anyone know if this could potentially be bad?
RT
Car: 1991 nissan king cab pick up
Only if they are resistor wires or not. Not sure if d21 uses resistor wires or not , but if they are and d21 is not or if they are not and d21 is would there be any chance of a problem. if they work you should be good to go. Not sure if the resistance would be enought to cause any troubles.
