lagvoid »
https://forums.nicoclub.com/lagvoid-u2836.html
Sat Jan 11, 2003 10:53 am
After doing lots of searching I did come across the self diagnosis test for the check engine light. After doing the test, I can't break them down to figure our what I need to replace/repair. I've tried searching for codes but had no luck. Please assist me in any way that you can.
1995 240sx se (non california)Error code 133 - E exhaust gas O2 sensor circuit3 long beeps and 3 short beeps*I assume that the O2 sensor simply needs to be replaced
Error code 234 - Detonation sensor circuit3 long beeps and 4 short beeps*Is my engine detonating? or did something else fail?
Error code 3Not sure what the code means...I read 10 long beeps and 3 short beeps, this doesn't seem right? Anyone know what that error code is?
I took short video clips of the error codes if it helps.Error code 1 Error code 2 Error code 3
If you know what needs to be replaced/repaired, please instruct me on how to go about it the best way.Thanks for your help
