Update: OK got the carpet painted black. There were Uber stains all over the thing. So I decided to give the carpet a new life. After all, its not worn very much at all just a bunch o' rust and whatever stains. So for your amusement are some before and after photos. Hope you enjoy!
BEFORE:
AFTER:
OK now the question. In "ILikeMy240sx" write-up on timing chain for the DOHC found here,
zer...age=1, maybe I didn't see it but the timing chain guides, should I remove them or replace them. I've got that rattle-can/marble in the can sound coming from the front of the head/valve cover, so I just want to be sure I can safely remove them or replace them.
Got the e-brake fixed as well. I spent 10minutes the other day wrenching on the handles' bolt connected to the cable to tighten it up. It still didn't work. So my buddy grabbed his air wratchet and went away with it. FINALLY it worked. LOL it was REALLY loose, IDK why but I do know that I need new rear pads. I hear metal grinding. FTL.
