getflushed »
https://forums.nicoclub.com/getflushed-u178201.html
Mon Jan 31, 2011 7:17 pm
hey guys!
new hear, thought i would try a different forum cuz i cant seem to get a good answer from my original forum, they r great help over there though!
so i have a 2000 maxima auto, with 140,000kms on it, so when i start my car in the morning, its really hard to start once i get it fired up ( i have a little trick to get it to start on the first try but will explain after) while i sit in my underground while it warms up if i give it a bit of gas to get it around 2000 rpm it will hang at 2000rpm and all by itself drop to 1800 for a brief second then to 1500 and hang there and you can hear the rpms pulsate a bit, i can push harder it wont move for the first little bit so i push harder, then boom it shoots up to like three grand. if i push the accelerator hard it revs normally its only when i feather it to 2000 rpm, the other related issue is if i dont let it fully warm up and drive off slowly, i can feel it hesitating, it feels simular to really warped rotors while accelerating and dissapears once its over 2000 rpm. i can still feel it when its warmed up but its not nearly as bad, i can feel it if im cruising around on flat surfaces at any speed lower than 70 kilometers in between 1500 to 2000 rpm, also when i take off from a red light i can feel kinda like a couple misses in the same rpm range. another thing which i think is related if im approaching a red light and it turns green befor i fully stop and i re apply the gas it hesitates big time between shifts. i dont know what it is but heres what ive done and maybe you guys can put me in the right derection
new pump and sock
new plenum gasket( checked for vac leaks and there is none)
tps tested ok
maf sensor was cleaned and tested but i dont know if the numbers are right for it i have them if you want me to post them
new plugs
new air filter
new coolant temp sensor
no missfires
fuel pressure is good
so the trick to starting it perfectly is either i let it crank for 2 seconds knowing it wont start and try again right after it will fire right up, but to get it to start on the first try i have to turn the key to acc then start slowly turning it, and right befor it starts to kick the motor over i can hear my fp run let it re prime the motor and it will fire right up , even with starting it the wierd way i will still have the hesitation though, but at least it will start up on the first try!~
please help me guys!
