Best_Shot »
https://forums.nicoclub.com/best-shot-u62114.html
Tue Jun 17, 2008 10:23 am
Let me try to understand this: is the vehicle cursor always in CA? If that is the case, maybe the GPS antenna cable is disconnected, but you also mentioned that when you enter address it shows no data - were you able to use the navigation at all in your area (Ohio)? When you are just driving around and no destination set in your nav, do you see the vehicle cursor moving and actually shows the map of your current location? Has your navi worked okay before? or this vehicle is just new to you, and this is the first time you use your navi?
My second assumption is that you DVD map disc is damaged. If not, then there is something terribly wrong with your navi unit, which is located under the front passenger seat...
