Ok, sorry i didn't get back to you last night but i stayed at my friend's house. Sounds like we have the same series of books (Precalculus with Limits a graphing approach published by Houghton Mifflin?), except i have the second edition. Hopefully they're pretty close to the same thing. Ok, in my book it's in section 6.1, Law of Sines on page 468. The question is:
Engine Design, The connecting rod in an engine is 6 inches in length and the radius of the crankshaft is 1.5 inches. Let d be the distance the piston is from the top of it's stroke for the angle "theta"
Part a: Use a graphing utility to complete the table - then you have to give the distance from top dead center when the angle of the crankshaft (theta) =0, 45, 90, 135, and 180 degrees.
Part b: The spark plug fires at theta = 5 degrees before top dead center. How far is the piston from the top of it's stroke at this time? and it has a little drawing of an engine.
Hope that helps or at least you'll be able to find something similar in your book.
Also, the links that Cory gave to team-integra.net are very good. I'm a member there and they have some very good general engine information...definately worth signing up for.
and i don't know if this site will help because i haven't read through it all the way but you can try
http://autozine.kyul.net/techn...x.htm
Good Luck,-Jon-
