Please HELP ME
jimmitoman
I have a 1992 240sx (ka motor) with 77k.The car idles rough and the rpm's drop when I press the clutch fast. The weird thing is that when I turn the Air conditioning on at idle the rpm's drop really low and the whole car starts to shake violently.Any advice would be helpful. Thank You
eastcoastchaos
Car: 95 240sx
hell yeah i had the same problem, mostly when it is really cold out.it has even gone as far as stalling a couple times when the clutch is depressed. if anyone knows whats going on please help
b240
Welcome to the boards jimmitoman.Did you try using the SEARCH button? I know this has been discused already. Also the faw has some things that will help out as well. Also 92 with 77k **** thats not bad at all.
YamaOni
Car: Its ugly and green, Its a cefiro dori machine
You might have a bad TOB, so when you push in the clutch that would drop the rpm or kill it.
