piston rings question plz help
pollitoboy
Car: 300zx 2=2 Na
i was looking in the online manual for z32.. imdoing a rebuild and i honed out my walls.. ok the online mnual says the the standard size piston rings are 87.00mm - 87.30 mm
then it states that the wear limit is 0.20mm...
so after my honing out of he cylinder walls u measured and ive honed out 0.18mmdoes that mean i can use stock size piston rings or do i have to get bigger rings?
hopefully u guys understood me.. i rally need ur help... thanks guys...
heres the link if u wanna see wat i was talking about..its the PISTON TO BORE section:http://www.300zx.co.uk/cgi-bin...al=70
